Camaro Coolant Leak????
Old 04-08-2017, 10:55 AM
Bboyphil's Avatar
the heater cores its not easy ,but stick around hear you will learn alot ,an do be sorry for things,your just learning your a good kid i am sure of that
Thanks man!! I appreciate the support, yeah I want to learn and gain knowledge about these things because I believe it is essential to know.
Again thanks!
  #92
Old 04-08-2017, 11:03 AM
This is starting to look more like an failed intake gasket. Check you oil make sure there is not coolant in there. If there is it will look like a brown milkshake.
  #93
Old 04-08-2017, 11:06 AM
Bboyphil's Avatar
Ohhh boy that doesn't sound too good I checked the oil dipstick and the color of it is brownish-blackish and smells like gasoline
  #94
Old 04-08-2017, 11:17 AM
95 camaro 406's Avatar
milky brown tan would not be good
  #95
Old 04-08-2017, 11:19 AM
Bboyphil's Avatar
Oh boy... My dipstick did not look milky though
  #96
Old 04-08-2017, 02:09 PM
if your getting coolant at the top of the engine then i would agree with gorn, i would say most likely the intake gasket and would explain the coolant at the rear going onto exhaust.
  #97
Old 04-08-2017, 02:14 PM
Bboyphil's Avatar
Hmm if it is the intake gasket would it drip down to the bolt under the oil filter and the k member as in the video
  #98
Old 04-08-2017, 02:36 PM
yes couse it leaks right from the intake as well
  #99
Old 04-08-2017, 02:40 PM
Bboyphil's Avatar
Aghh I really was praying that it wasn't the intake... the mechanic quoted me $650
  #100
Old 04-08-2017, 05:01 PM
yes it could im not sure how common it would be for it to leak from different locations. you could have more than one leak.
Quick Reply: Camaro Coolant Leak????
