Camarillo 2002 won’t start
Old May 17, 2019 | 04:00 PM
Nick Sisto's Avatar
Default Camarillo 2002 won’t start
At wits end. Ran out of gas now car won’t start. Have done everything! Anything suggestions
Tank Faulk. Fuel pump works. Gas at Schader valve. Car crank a bit won’t start. Spraying starter fluid. It fires bit won’t start continues to crank.
Old May 19, 2019 | 07:31 AM
check fuel filter, remove and dump in clear container from tank side of filter, look for water and or crud plugging it up. if you dont got plugged filter or water then most likely fuel pump is toast. fuel at the rail doesn't mean you have enough pressure or fuel flow to make it run.
cardo316
Sep 19, 2013 07:51 PM
flim101
Jan 7, 2012 08:00 PM
imtico
Oct 16, 2007 10:32 PM
r.serio
Dec 11, 2006 04:56 PM
Joe7583
Aug 9, 2006 09:14 PM
