a/c low pressure switch
I think the a/c pressure switch located on the passenger side of the engine compartment right in front of the coolant reservoir. The shiny long refrigerant line has the port covered with a screw off cap.
Low side pressure on a functioning system should be in the 30-40 PSI. Do not jump that switch for more then a second or two. If you are really low on freon the compressor can be damaged since the freon carries the oil.
