A/c help
Old Oct 3, 2014 | 07:45 AM
c928bran's Avatar
Default A/c help
I noticed, when i first turn my key on to start my car, the a/c compressor clutch engages for about 3 seconds. I dont think this is normal, is it?
Thanks, Craig.
Old Oct 3, 2014 | 09:46 AM
mrfreez's Avatar
Does your AC work? If so then it's normal to cycle to get rid of any excess condensation out of the condenser. It's only for 3 seconds so no need to worry about it.
Old Oct 3, 2014 | 12:47 PM
c928bran's Avatar
car is not running, when it does this, and the a/c switch is off
Old Oct 4, 2014 | 02:09 PM
v64thgen's Avatar
Are you sure it's not the fuel pump you are hearing? When you turn the key to the on position the fuel pump turns on and can usually be heard.
Old Oct 4, 2014 | 06:06 PM
Check your heater controls. If they are in the defrost position, that activates/cycles the air conditioning to remove humidity from the cabin.
Old Oct 5, 2014 | 07:53 AM
c928bran's Avatar
it is for sure the compressor, and not the fuel pump. i unplugged the compressor clutch coil wire, so it would not engage.
