Burnin rich update
Old Mar 21, 2011 | 03:53 PM
auto's Avatar
Default Burnin rich update
was nosing around and saw some other people having the same problem. their fix was swaping out the air control valves since it wouldnt close properly. for 12 bucks i said what the hell. now i dont smell the gassy exhaust, it smells more regular like before.
tested fuel pressure- 53psi key on for 1 hr, running 60 psi steady
swapped all 4 o2 sensors with delcos'
2 air catch valves
i drove 17 miles before today, took 2.4 gals works out 7.08 mpg
when i hit 17 miles again, will post if theres any difference.
btw has anyone ever hear about the catch valve issue?
Old Mar 21, 2011 | 04:23 PM
MelloYello's Avatar
what on earth is an "air catch valve"???
Old Mar 21, 2011 | 04:50 PM
auto's Avatar
this thing shaped like a hockey puck between air pipe from the exhaust manifold and a rubber hose
Old Mar 21, 2011 | 05:13 PM
Massey's Avatar
You mean Air Check Valve That is a one way valve that keeps the exhaust from entering the AIR pump and hoses. When they go bad they will allow the exhaust to enter the system and ruin the hoses and or pump.
Massey
Old Mar 21, 2011 | 05:15 PM
auto's Avatar
hmm.. :P i guess i did mean air check valve...
Old Mar 21, 2011 | 05:46 PM
MelloYello's Avatar
are we talking about a fourth generation camaro? i didnt think these new cars had air injection systems... i knew the 3rd gen 305 emissions bogged poop setups did...
Old Mar 21, 2011 | 05:49 PM
auto's Avatar
yep 2000 v8 camaro
Old Mar 21, 2011 | 06:14 PM
MelloYello's Avatar
ummm am i mistaken but i didnt think LS1 had secondary air injection system
Old Mar 25, 2011 | 09:51 PM
auto's Avatar
okay so with the new catch valve im getting 8.8 mpg city
gettin there
Old Mar 26, 2011 | 03:40 AM
Massey's Avatar
The air system is there, one port into each exhaust manifold. The pump is behind the bumper on the driver's side. It is electric and does not rob any HP so it is best to just leave it alone.
Massey
