THE BUILD IS UNDER WAY !!!!!!
#22
RE: THE BUILD IS UNDER WAY !!!!!!
yea im getting all the parts i need from him , i was on the phone with him for bout 25 min discussing my gaols and budget . We put together a nice packadge that he said i should easily see 425 + with what i have already heres what he sent me im getting done
[align=left]200cc Dominator LT1 CNC Head & Cam Package[/align][align=left]CNC'ed Intake Port,Exhaust Port,& Chamber[/align][align=left]CNC'ed F1 Quality Competition Valve Job (<3 microns TIR)[/align][align=left]Machine Intake/Exhaust Flanges & Valve Cover Rails To Ensure Proper Port Alignment & Sealing[/align][align=left]Machine Guides For Any Future Spring Upgrades[/align][align=left]Deck is PCD Milled For Superior Surface Finish, Flatness, and Desired Chamber Volume (52cc - 56cc)[/align][align=left]Completely Hand De-burred To Remove All Sharp Edges[/align][align=left]Hydrostatically Pressure Tested & Hardness Checked to Ensure the Casting's Integrity[/align][align=left]Custom Manley Pro-Flo Severe Duty Stainless Valves 2.00 Int/1.56Exh w/Hi-Performance Metal Clad[/align][align=left]Viton Valve Seals[/align][align=left]Pacaloy 1220 Beehive Spring w/Custom Hardened & Machined 10deg Steel Components (Not Inferior[/align][align=left]Stamped Parts)[/align][align=left][/align][align=left]Custom Induction Hardened 8620 Billet Core Hyd Roller Camshaft w/Premium Everwear Gear Compatible[/align][align=left]w/all Type Oil Pump Gears[/align][align=left]1 [/align][align=left][/align][align=left]1 Basic Inlet Street/Strip LTx Intake Manifold Porting [/align][align=left][/align][align=left]TFS-89036 36# Fuel Injector Set (Stainless Body & Flow/Impedance Verified @ 1.5% or less) [/align][align=left][/align][align=left]Ai HIGH PERFORMANCE HYDRAULIC ROLLER KIT[/align][align=left]CC1305 Pro-Magnum Rocker Arm 1.6 Ratio[/align][align=left]ARP 234-7202 7/16" ProSeries Rocker Studs[/align][align=left]GMPP 12371042 Hi-Performance HydRoller Lifter Kit[/align][align=left]Custom LT1 Guideplates Hardened 4130 ChromMoly[/align][align=left]CVP .080 Wall Thk 4130 ChromMoly Hardened Pushrods 5/16" x 7.xxx[/align][align=left]CC7202 Hi-Tech Pushrod Length Checking Tool[/align][align=left](For Correct Valve Train Geometry You Must Measure)[/align][align=left]1 [/align][align=left]Ai GASKET & HEAD BOLT KIT:[/align][align=left]GM-12553160 LT1 Head Gasket .029 Thk x 4.100 Bore[/align][align=left]FelPro-1284 Intake Manifold Gasket w/RTV[/align][align=left]FelPro-45956 Timing Cover/Water Pump Gasket Set[/align]-
ARP 134-3601 High Performance Cylinder Head Bolt Kit
and its allfor great price and below my budget .!!
#25
yea im lookin into that , they got some lakewood products out that look pretty good ... Im gonna tie the frame up , and do a strut tower brace, and put new struts front and back , and some sorta tracion mod in the rear any one got any ideas ? my buddy is looking for a 12 bolt rear for me right now .. i just wanna have the car top shape for the spring ya know i dont wanna go out to the strip the first day and blow the rear or somthing im also looking into a aluminum drive shaft with a loop
#27
ORIGINAL: whammer3024
rear lower control arms and relocation brackets, panhard bar, torque arm
#28
ok im gonna get some more stuff i saved a few bucks on the motor going with ai so that frees up a bit of cash for a 12 bolt ans some traction toys ..ohh i forgot to mention i bought a set of draglites with mickeys stickeys dots on the back i havnt orderd the fronts yet due to lack of knowledge on the size, my s10 i built i had 5 inch front runners but im not sure what to run on my z any thoughts ..??. man this car should end up being a pretty bad *** street car lol!! I wonder what its gonna run ? It wont measure up to my pops 1100 hp c5 vette(he keeps reminding me of that too ) but not its to bad for my first lt1 hahaha well anyways thanks guys for the help i really apprciate it !!!!!!! if you guys think of anything else or found some good deals lemme know k thanks again
#29
for the front 15x3.5 and if ur not usin them for the street look into ds-2's there the lightest. and my guess would be 11s. i forget r u sprayin it? if you r u might be knockin on the 10s door you have a real nice set up that your makin nicer. this has been one of the most interesting threads ive read on here so far.
#30
ok i will look into them .. Yea im gonna spray 75 or a 100 wet shot to it on the track only ..im really stoked to get it done !! and best be sure im gonna have a video of its first start and first run at the track and mabey i will sneak a dyno vid up after i run it juuuust in case my compotion here in my town get wind of the dyno vid lol dont wanna let any secrets out b4 we race lol
