Brake indicator on dash
My brake indicator on the dash came on tonight. I parked at the store everything was normal. Started car and brake light was on. I have checked the fluid level. There are no leaks at any wheel. I can find no leaks down any hoses or hard lines. I pulled the rear wheels. Everything seems fine. I have just over 1/8" of lining on the shoes. The front pads are a little over 1/16" before the squeaker hits.
Also, the ABS Inop light has been on for about 2 months.
Pedal feels normal. Doesn't go down more than usual. Feels pretty firm. Car stops great.
Suggestions???
Bleed brakes? Replace pads / shoes?
I tried removing the connector from the block on the side of the ABS unit...light did not go out.
When I parked, I did not use the hand brake since I was parked on flat land.
Suggestions???
brake light would be with brakes or e brake. maybe stuck e brake light switch. try putting the e brake on and off a few times to see if it does anything. if its in the brake system you can reset it by pushing really hard on the brakes. i mean hard. that may cause the problem to show too.
GrandmasCar
08-15-2010 12:35 AM
wiserocz
04-28-2009 04:44 PM
