Bloody Rattle !!
Old Oct 14, 2022 | 10:31 AM
Wruff's Avatar
Default Bloody Rattle !!
95 Camaro. Got the most annoying rattle rear passenger side.
Still there when spare wheel is removed.
Antennae support solid.
Not shock mount loose top or bottom end.
Nothing loose on suspension.
Nothing loose behind carpet on rear. Hatch secure.
WDF !!
Any clues out there ?
Old Oct 14, 2022 | 04:26 PM
Check exhaust system,hangers might be toast. Grab the pipes and push up and down on them.
Old Oct 14, 2022 | 08:42 PM
Wruff's Avatar
Looked at that and packed hangers, bent hangers....no dice but thanks.
At $50 a pair, I sit and wonder each time it rattles !!
Old Oct 14, 2022 | 09:42 PM
TheRealHip's Avatar
Heat shield between muffler and gas tank?
Old Oct 18, 2022 | 08:50 AM
when does it rattle, all the time, throttle up, hitting bumps, etc
Old Oct 18, 2022 | 11:16 AM
I hate rattles. I have had to ride under hoods and in trunks to track them down on brand new cars. Once you track down the area maybe a Camera mounted in the area? I saw on online guy go crazy with a noise under acceleration he thought it was something rubbing. Turned out the camera picked up the axel tube turning under acieration. Had to weld up the axle.
mickeykelley
Oct 30, 2011 09:14 PM
85olds4spd
Nov 8, 2008 01:58 PM
85olds4spd
Nov 8, 2008 01:52 PM
deang423
Jan 21, 2008 04:59 PM
nitrojunkie
Dec 28, 2007 02:14 AM
