bleeding cooling system
Old Feb 14, 2010 | 06:49 PM
skinut's Avatar
Default bleeding cooling system
Who can tell me how to properly bleed the cooling system on a 95 lt1??
Old Feb 14, 2010 | 10:58 PM
nnewquist's Avatar
I'm not 100% sure on that engine, but there's usually a bleed screw on or around the thermostat housing. Get the engine up to normal operating temp. Then you undo the screw until coolant leaks out. If there's any air in the system, it'll bubble out. When the coolant comes in a solid stream, you know the air is all bled out.
Usually, it's a good idea to do this several times. Depending on the location of the bleed screw, it might be a good idea to park facing uphill or on ramps/stands. You want the screw to be the highest point in the cooling system, so the air can properly rize to the bleed point.
NoSoupForYou83
Feb 20, 2013 08:57 AM
juice+
Oct 13, 2012 07:13 AM
67Harbor
May 21, 2010 01:36 PM
fergie24
Apr 14, 2010 06:52 AM
WaveHunter
Jun 3, 2009 06:19 PM
