Is the bcm different in a 1997 than a 2000?
Old Oct 4, 2009 | 11:11 AM
siueparent's Avatar
Default Is the bcm different in a 1997 than a 2000?
Is the 1997 and 2000 bcm the same?
Old Oct 4, 2009 | 04:09 PM
lt4weeda's Avatar
well seeing how a bcm is programmed to work with a specific pcm and now a 97 had a lt and the 2000 would have a ls, figureing you have a v8. I would say they would be different for that portion of the programmed, however for the controls for everything else I am not sure.
Old Oct 4, 2009 | 04:12 PM
siueparent's Avatar
Thanks I figured i'll just get mine tunned to get rid of this pass key system.
Old Oct 4, 2009 | 05:30 PM
javb_vb's Avatar
u have problem with the pass key system? use a potentiometer to know what resistor u need. it is easyer that buy all the keys or reprogram
Old Oct 4, 2009 | 09:26 PM
siueparent's Avatar
Yes im having a problem with the pass key system. How do I do it with a potentiometer?
Old Oct 5, 2009 | 11:04 AM
javb_vb's Avatar
the file
File Type: zip
Old Oct 6, 2009 | 03:49 PM
siueparent's Avatar
the file
Thanks worked great
siueparent
Nov 9, 2009 08:08 PM
siueparent
Sep 29, 2009 07:54 PM
94V8jag
Apr 22, 2008 09:59 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
hasenbonkers
VS
10
Jun 22, 2006 09:45 PM
