batt drain and clicking under gas peddle
I have 94 v6 rebuilt fuels system new muffler getting car on road again and after driving round neighborhood park car and come back 15 min l8tr clicking under right side of gas peddle. I think might be a relay but don't know. Any suggestions?
Check your battery, It sounds like the start is not getting enough power.
Could be battery, connection, cables or the starter going bad.
Edit: When does it click? I assumed when you are trying to start the car?
Its not batt. When I turn car of I just found out the radio stays on. When u open door radio doesn't turn off. When the clicking started again I pulled the radio fuse and it stoped.To the right of the gas peddle on fire wll there is some duckt work and I fund the clicking relay but don't know what relay it is or how 2 get to it
It sounds like the relay is in the Retained Accessory Power (RAP) module, which is about the location you mentioned. I'm not sure how pulling the fuse could stop it unless the radio is shorting it out. Check the value of the radio fuse. it should be 15 amps. The RAP module is what switches off the radio when the door opens. That module could be defective or the fusible link that suplies power could be intermittent. Do you have any trouble with the wipers when this is happening? The wipers are on the same fusible link circuit.
StreetLethalZ
10-28-2006 02:26 PM
