Bad idle can you help please!!
Old 08-25-2009, 02:44 PM
probly just something on the exhaust manifold. check for anything leaking and anything against the manifold. if ok drive it to the store and get a soda and check after. if its still smoking then look again for leaks.
Old 08-25-2009, 02:55 PM
sscamaross's Avatar
ive been hearing about inductive crossfire what is that? i couldnt get a few of the clips from the factory back on the wire because they broke will that have anything to do with it? after i made dure evcerything was tight and re checked to see if they were plugged into the right spot and everything checked out.
Old 08-25-2009, 03:02 PM
if there new wires should not have cross fire. pick up some looms at the parts store if u want. yah if nothin on the exhaust manifold run it for a bit and see if it clears up.
Old 08-25-2009, 04:11 PM
sscamaross's Avatar
ok did that and stopped smoking. only problem is car runs same as it did before so it wasnt the wires. took it over to a friend of mine who has a scanner and a code came up for the air pump. would that have anything to do with how it idles when in gear like i discribed or no? i dont know anything about them. thanks again
r00tk1ll
02-06-2015 10:25 PM
Rustyshackleford1911
12-27-2014 09:32 AM
millspec96ss
12-12-2009 10:47 AM
92rs_guy
04-09-2009 11:20 PM
6v49der
01-03-2007 01:51 AM
Quick Reply: Bad idle can you help please!!
