B&M Electronic shift controller
Old Nov 20, 2010 | 11:07 PM
VALHAR's Avatar
Default B&M Electronic shift controller
[IMG][/IMG]
On my 95 Z28. Running the Electronic shift controller wires to the PCM with out having to drill any holes.
Remove the passenger kick panel and to the right of the ac. blower motor you will see where that wire bundle comes through from the engine bay.
After removing the PCM. I then used a scratch awl and punched a hole in the gromet from the engine side located just behind the PCM.
Then using some safety wire I fed through the gromet from the engine bay side. I crimped the safety wire to B&M cable wires and just pulled it through into the engine bay. Dun with no drilling.
You might want to use some RTV on the B&M wire clamp splices before you clamp them together, for a water tight connection.
Old Nov 21, 2010 | 08:07 AM
more pictures and info would be great.
pcarollo
Apr 8, 2014 03:52 AM
th3po1son
Jan 20, 2008 08:56 PM
iamgman
Dec 13, 2007 10:03 PM
lt1z28
Nov 15, 2007 09:17 AM
