auto door locks PLEASE HELP!
Old Dec 31, 2009 | 08:42 AM
evelcaterpillar's Avatar
Default auto door locks PLEASE HELP!
Hi i am new....first post actually and i have looked for an answer to this and was unable to find it! I was sure itd be a sticky somewhere but i havent seen it so im sry if its already been posted please direct me! when i start my car the doors lock automatically and this generally isnt a problem unless you are like me and live in indiana where its cold and you go out open your door lean in start the car shau the door and go back inside for 10 min then when ya come back out your car is warm and running but unfortunatly u cant get in it! Please someone tell me how to bypass this feature.....i DO NOT wanna just take out the fuse as some sites have suggested.....there has to be one of those weird turn the key hook the seatbelt flash the light codes! Thanks!
Old Dec 31, 2009 | 09:29 AM
DrQuincy's Avatar
Question
K... I'll ask... What year?
Old Dec 31, 2009 | 09:51 AM
osduck5's Avatar
On some vehicles, there is a way to set the locks by inserting key in ignition and doing a song and dance per the operators manual but you would need to find the operators manual for your particular vehicle and see if it tells you how to disable the auto lock.
Old Dec 31, 2009 | 12:25 PM
RedKnight's Avatar
I'm sure I'm wrong, but shouldn't the locks engage only after putting the car in gear? I'm just going off familiarity with automatics. If so, maybe there is a faulty relay somewhere.
Old Dec 31, 2009 | 12:28 PM
Depending on what year. Up to 95 check the RAP module; 96 and newer, check the BCM (Body Control Module). Or you can always use your spare key to unlock the door. Hopefully, you don't have an add on alarm to cause confusion.
Old Dec 31, 2009 | 01:16 PM
DrQuincy's Avatar
Hmm... Was this feature even available in '95? My Z doesn't seem to have it...
Old Dec 31, 2009 | 08:31 PM
The RAP module was standard in all early 4th gen Camaros, in later models the RAP function became part of the BCM.
Old Jan 1, 2010 | 03:55 PM
o sry it is a 1995. I have the manual and i never thought to look to see if there was a code in there. As far as i am aware the car does not have an aftermarket alarm, and i do not have a fob for the doors or nething like that. and i know that most automatics lock when put in gear but this one locks as soon as u start the car, and i do keep an extra key for emergancies but its a pain in the a$$ to have to dig in my wallet to get the spare key when its 10 degrees outside!
Old Jan 1, 2010 | 03:57 PM
thanks for the info guys ill keep lookin to see if anyone else has suggestions and ill post if i get it figured out
silverrocker84
Jul 26, 2011 01:26 PM
80z28guy
70-81 V8 Tech
Jul 19, 2009 03:04 PM
markcamaro
Aug 23, 2008 04:33 PM
streetrace06
Jun 29, 2008 05:03 PM
mikew6459
May 13, 2008 04:59 PM
