Any ideas on how to attach this grill?
I bought this grill used a few months back and I had it painted black. The guy I bought it from attached it with zip ties. Id rather secure it with screws/bolts etc. The problem is, the slats are about an 1/8 inch apart. There are 4 square pieces that look like you could put tape there, but I dont think 3M tape will hold it on long term. I included a pic of the front of my car so you can see where it would be going. The outer two squares are located over the foglight holes, so I dont see how I could use those, even if I was going to use 3M tape. Thought maybe someone had this grill and had installed it before. Any ideas?
![](http://i802.photobucket.com/albums/yy302/gearheadgirl/grill2.jpg)
![](http://i802.photobucket.com/albums/yy302/gearheadgirl/grill.jpg)
![](http://i802.photobucket.com/albums/yy302/gearheadgirl/grill3.jpg)
![](http://i802.photobucket.com/albums/yy302/gearheadgirl/grill4.jpg)
im sure 3m auto tape will work thats how they attach emblems and some trim now its pretty strong sht
or some little bolts into your bumper and and then use some ny-lock nuts on the inside
btw i love your car its looks awesome
he did say hed rather not use zip ties plus his nice *** car with some zip ties holding that grill on would look shtty as hell
Thanks for the compliments. Ill try the 3M tape. I'd rather try that first than drill into the bumper. However, I have holes in it already from the previous owner putting a liscence plate on it and I was going to use those, but since the slats are so close together I cant find a screw head that will fit between them. I dont want a nasty screw/bolt head sticking out from the slats. Know what i mean? Sounds like 3M tape is my only option. I just wonder how the manufacturer intended it to be mounted.
My foglights on this car are aftermarket, but my previous car (94 camaro) had the stock foglights and they fit fine behind the grill.
