All 1994 z28 camaro owners
Old Apr 17, 2011 | 08:16 PM
Z28Freak's Avatar
Default All 1994 z28 camaro owners
Can anyone with this model please attach a picture of the fuse box under the hood. I recently bought the car and I'm not sure that all of the fuses are there. I just need to know if I need to go ahead and do some wiring. Thanks!
Old Apr 18, 2011 | 01:10 PM
Massey's Avatar
Not all locations will be filled with fuses. It is going to depend on the options your car came with. Look on the box cover there should be a diagram or legend that will tell you what fuses go where and what size. If you have an option that is lised but no fuse (ie Air Conditioning) you may need to put a fuse in there.
Massey
Old Apr 18, 2011 | 01:11 PM
Massey's Avatar
Also some locations may be for relays and not fuses so make sure you check to see if you have the option for the relay before stuffing one in there as well.
Massey
Old May 14, 2011 | 05:14 PM
1994bigd's Avatar
need to know why cylinder 2 and 4 are not firing
Old May 14, 2011 | 05:16 PM
1994bigd's Avatar
thought it was injectors , so i changed those , still sounds like its running on 6 cylinders, feels sluggish and little back fire . anny answers??
Old May 14, 2011 | 07:08 PM
Z28Freak's Avatar
Spark plugs, plug wires, and opti would be where I would start.
Old May 14, 2011 | 07:53 PM
3800camaro's Avatar
Sounds like an opti problem. Have you done anything that might have caused some coolant to get on your opti?
Old May 24, 2011 | 06:34 PM
androzer's Avatar
Cool catalog
Dude in the catalog ( manual) u can find this diagram u are searching for
if u need help i can picture mine and post it for u
proud to have 1994 obd1 ahhahahah
wish it was obd2 so i can connect some features,,,,,,,,,,,,digital display .
75cam
May 6, 2013 07:33 AM
73camaroSS
Oct 21, 2009 12:03 AM
pimparsons
South
Mar 12, 2009 09:49 PM
