All 1994 z28 camaro owners
Can anyone with this model please attach a picture of the fuse box under the hood. I recently bought the car and I'm not sure that all of the fuses are there. I just need to know if I need to go ahead and do some wiring. Thanks!
Not all locations will be filled with fuses. It is going to depend on the options your car came with. Look on the box cover there should be a diagram or legend that will tell you what fuses go where and what size. If you have an option that is lised but no fuse (ie Air Conditioning) you may need to put a fuse in there.
Massey |
Also some locations may be for relays and not fuses so make sure you check to see if you have the option for the relay before stuffing one in there as well.
Massey |
need to know why cylinder 2 and 4 are not firing
thought it was injectors , so i changed those , still sounds like its running on 6 cylinders, feels sluggish and little back fire . anny answers??
Spark plugs, plug wires, and opti would be where I would start.
Sounds like an opti problem. Have you done anything that might have caused some coolant to get on your opti?
catalog
Dude in the catalog ( manual) u can find this diagram u are searching for
if u need help i can picture mine and post it for u proud to have 1994 obd1 ahhahahah wish it was obd2 so i can connect some features,,,,,,,,,,,,digital display . |
