Airconditioning blows at the floor Fourth generation.
Old Jul 4, 2010 | 01:33 AM
RSSSCamaro's Avatar
Default Airconditioning blows at the floor Fourth generation.
I have a 1996 Camaro that originally came with a 3.8 A4. I swapped from a 2000 Z-28 with an A4. I changed everything over, wiring, plumbing, dash, etc etc. The only problem I have is that the Airconditioning blows at the feet. The only control I have is for the feet on other settings without A/C and Defrost (towards the windshield) What do I need to look for so that the airconditioning blows out of the proper dash vents.
I think it may be a plunger, or a vacuum leak, I just don't know where to begin to look. This is the only problem I had after the swap. Please help.
Old Jul 4, 2010 | 02:30 AM
i think these are the same for your yr.
Size:  51.0 KBName:  P4290001_2.jpg
Old Jul 9, 2010 | 02:05 AM
RSSSCamaro's Avatar
Default AC
Thank you Craby, I will definitely have to look into this.
Old Jul 14, 2010 | 06:01 PM
superjatt's Avatar
Hay thanks for the info . will be needing this.
Old Jul 14, 2010 | 10:32 PM
RFxCamaro's Avatar
i had the same problem on my 3.8 check vacuum lines, and evap canister
Old Jul 15, 2010 | 08:28 AM
RSSSCamaro's Avatar
I started using it regularly, and now it works like it should, I dunno why. It must have been a lack of use issue. Thank you all for your help.
Schuy69
Jan 6, 2011 09:40 PM
BasicConcepts
Dec 5, 2010 10:50 PM
squintos_89
LS Series Tech
Oct 24, 2009 12:57 PM
azmattaz06
Aug 4, 2009 03:03 AM
brey2448
Mar 21, 2008 04:55 PM
