Airbag and security light on, keep blowing horn fuse?
Old Dec 9, 2012 | 07:28 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Default Airbag and security light on, keep blowing horn fuse?
Hey everyone so my airbag light and security light came on recently. My car is originally a 93 with 97 engine/harness/ecu and everything swapped into it. I hit my keyless entry to set the alarm and it pops the horn fuse. When I first did the swap the red security light on the dash pad worked fine, and now it doesnt. The 93 also had two horns and wiring for both and I only found 1 plug for the 97 for a horn. My horn buttons on my steering wheel dont work because the plastic buttons were ruined. Could wires be touching in there shorting it out? Im not sure if the air bag light being on has to do with that either. The VATS is bypassed but I changed the bcm because it was failing so maybe that turned the security light on? Im not sure.
To shorten everything up:
Problems:
-Airbag Light and Security Light on
-Horn fuse blows when alarm is set with keyfob
-One connector for one horn and two horns are on my car.
-Horn buttons on steering wheel dont work.
Any help is greatly appreciated!
Thanks.
Old Dec 9, 2012 | 08:15 PM
sure sounds like a short in the coluum. get the ohm meter out and see if you can find any hot wires that show ground.
edog2
Sep 1, 2013 08:31 AM
vnctvega
Oct 18, 2012 11:31 AM
izayuhgawd
Nov 21, 2011 09:24 PM
Skyline
Nov 26, 2009 08:18 PM
golfballs
Aug 4, 2008 10:46 AM
