air conditioning question
Old Jul 29, 2008 | 11:52 AM
66Fastback's Avatar
Default air conditioning question
My brother has a 94 Z-28 LT-1 with air condioning and auto Heres the problem the guy he bought it from had taken the AC lines off the back of the compresor.. What do I need to do to get it running again it has a DELPHI 0964 compressor.. Any help???[:-]
Old Jul 29, 2008 | 12:08 PM
02StanGT's Avatar
Default RE: air conditioning question
A new drier, the rest of the hoses, vacuum pump to(evacuate the system), a few cans of refrigerant, some compressor oil, pressure gauge so not to overfill it, and good idea to lube o-rings so they don't dry out.
Old Jul 29, 2008 | 12:19 PM
66Fastback's Avatar
The bolt that holds the lines on the back of the compressor is gone any idea what size it is???
Old Jul 29, 2008 | 12:27 PM
02StanGT's Avatar
Hopefully someone else can help you with what size. I have no clue.
Old Jul 29, 2008 | 01:03 PM
MusicMan's Avatar
The Jazz Man
Most the refrigerant you buy these days has the oil already in it, read the can before you buy. Not sure about that bolt. Junk yard?
Old Jul 29, 2008 | 02:02 PM
66Fastback's Avatar
Heys guys another question the elec plug for the clutch is on the bottem the plug anly reaches about half way down on the passenger side of the compressor could he have put it in upside down???? Thx!!!!
Old Jul 29, 2008 | 08:30 PM
usarmyrangrs's Avatar
I'd actually buy the lines and have a professional install and perform the charging procedure. You will need to purchase the correct lines and dryer/accumulator to avoid contaminating the new refrigerant and new oil.
Burleyboy
May 12, 2013 06:47 PM
tjsmar
Jul 19, 2011 12:59 AM
Latinoeheat
Sep 18, 2008 03:02 PM
xCx777
Jan 31, 2008 07:43 AM
shibby426
Aug 23, 2007 12:50 PM
