ac not working
Old Jul 15, 2014 | 05:33 PM
warmeck's Avatar
Default ac not working
my ac dosent work as far as i know the fuse for it is no good...but is it worth getting it filled back up? could i do this myself?
Old Jul 15, 2014 | 07:31 PM
2Z's's Avatar
Did it simply stop working or did it slowly go from cold to blowing warm air over time? Is the blower just not working? Did it ever work? You need to be more descriptive when you have an issue, this way you will get better and more helpful answers! Yes, you can fill it up, but if its empty, that means theres a leak... I would have it tested and make sure theres no leak...at that point, you may as well have the shop fill it for you.
Old Jul 15, 2014 | 08:26 PM
replace the blown fuse and see what happens
Old Jul 16, 2014 | 09:59 AM
warmeck's Avatar
i do not know the previous owner said it didnt work so he removed the fuse and drained it.
Old Jul 16, 2014 | 10:45 AM
ahh so if its been setting for some time without anything in it your going to need to have it tested. first guess is compressor is a goner.
Old Jul 16, 2014 | 11:36 AM
warmeck's Avatar
oh jeeze didnt want to hear that lol but alright i will get it done!
Old Jul 16, 2014 | 08:17 PM
Not sure if you misunderstood him or he was a complete moron. You never drain a system that holds pressure. That pressure protects the seals. No AC tech would advise paying someone to draw the coolant out of a none working system. Pull the fuse maybe if the compressor was locked up but you do not drain the system until right before you fix it.
The only real reason for pulling the fuse is a locked up compressor. Locked up compressor are pretty big jobs because in most cases there is metal from the compressor all through the system. It all needs flushed out on top of the compressor replacement and if the system has been without pressure you need a dryer receiver also. Normally it is a good idea to replace the dryer receiver with the compressor but if the system has as zero pressure then it more like a requirement.
Old Jul 16, 2014 | 09:19 PM
warmeck's Avatar
yes he did say that, okay so what are the prices on this to be fixed by a shop?
Old Jul 16, 2014 | 09:31 PM
2Z's's Avatar
Its gonna depend on what parts you insist on...if you want all GM or equivelent, its going to be alot more in parts...If youre ok with parts that may be off shore...then youll pay alot less. I just went through what youre doing. I bought my stuff from Rock Auto. Compressor, dryer and expansion valve for about $225.00 The shop cost me another $150. for vacume, leak check and 134a fill.I did the parts replacement myself.
Old Jul 17, 2014 | 01:02 AM
Bo_Johnson's Avatar
Same here
justin1989
82-92 V8 Tech
Nov 4, 2007 01:12 AM
camaro girl
May 30, 2007 01:19 PM
MarkyMark
Jan 29, 2007 01:01 AM
