ABS Inop Light & Headlight issues SOLVED
Old Mar 26, 2012 | 01:12 PM
DashingDaryl's Avatar
Default ABS Inop Light & Headlight issues SOLVED
Hey guys. My ABS Inop light came on one day. During the day it would stay on for 4 engine starts and then go off. It would always be on at night.
I also noticed my driver's side headlight would be dim and my dash board left turn signal light would be on, dimly. Plus my fog light didn't work.
I was going to ask you all if you thought it might be BCM related, or a loose ground.
Turns out it was a loose ground. It was the ground on the driver's side, right by the radiator. Though it was tight, a good cleaning solved my problem.
Just thought I'd share.
P.S. The test for this is to turn on your headlights/Fog Lights and wiggle the ground. If there is a difference it is probably the ground. You can't use the ABS Inop as a check, because I think you have to restart your car like 3 times before the light clears.
jay2002Z28
Apr 22, 2014 06:06 AM
impala765
May 25, 2012 10:15 PM
rktect69
Nov 12, 2011 03:47 PM
hpd218
Aug 24, 2010 12:05 PM
Skiwee10
Aug 31, 2006 12:54 AM
