99 camaro her help
Old May 15, 2018 | 04:37 PM
Jason62$7@'s Avatar
Default 99 camaro her help
so I have a 99 camaro v6 I got on a very good deal.the problem I keep having is egr codes.ive replaced the valve checked the lines many time and every thing is in good order.motor runs good till I cut the ac on and the exhaust starts vibrating.dont know if the egr is the cause but the motor is not missing what so ever.its driving me crazy.it vibrates random sometimes.any advice would help.
Old May 15, 2018 | 06:24 PM
wondering if the a/c pump is not happy. ill move your post to the general section and we can see if that helps get some responses.
Old May 15, 2018 | 06:26 PM
done, download a factory service manual here, 99 svcman would be your year. http://www.mediafire.com/?40mfgeoe4ctti
Old May 15, 2018 | 06:58 PM
Y2K's Avatar
Y2K
my first thought too or maybe an idler pulley?
Old May 15, 2018 | 07:50 PM
Jason62$7@'s Avatar
Ac pump is new.it does it a little when ac is off. Also the idler bounces a lot while the car is running. I know another issue that started recently the alternator will quit charging with ac on for a sec.when I kick on the ac it will quit charging for a sec and then slowly the volts will rise.i put a meter on it that’s how I know that.with the lights and ac on it’s not pretty.it does not like it at all at idle.
Old May 15, 2018 | 07:58 PM
clean all your battery connections. battery posts, battery cable ends, wire ends at the alternator, maybe pull the wires off the power junction and wire brush the heck outa them too, should have a red plastic cover on it. your tensoner may be starting to go letting the belt slip. if its jumping something is not right. have you removed the belt and spun the idler, tensioner and alternator to see if they is unhappy.
Old May 15, 2018 | 08:00 PM
Once the RPMs fall below a certain value the alternator stops outputting any real amps. This sounds like an Idle.
What codes are you getting? if a vacuum switch is leaking and cause the EGR to open at idle that would explain everything.
Old May 15, 2018 | 08:06 PM
Jason62$7@'s Avatar
P0403
p0405
p1404
im very sure everything is clean and working on egr side.
my idle is about 700 maybe or close with ac on
Old May 15, 2018 | 08:08 PM
Jason62$7@'s Avatar
I can unplug egr and still does it.also every once in awhile the motor will rew up and down live I got a cam.it don’t do that often tho.
Old May 16, 2018 | 06:11 AM
If you have a new non-stock Cam the car will need tuned. The stock tune may work in some cases but I have never seen a Cam change not have any effect on the tune. Also with a tune you could wake up the motor.
Do all those codes set instantly or do they take time? Which one is first? that is the one you need to track down. PCMs don't throw codes if everything is working unless the PCM itself is fried.
