98 chevy camaro v6 intermittently stalling and wont restart
Old Jul 26, 2017 | 08:36 PM
Jmm5712's Avatar
Default 98 chevy camaro v6 intermittently stalling and wont restart
I have a 98 camaro with the 3800 series 2.fuel pump was replaced,fuel filter replaced,idle control air valve replaced.ignition control module was removed and tested good.get in the car start it,runs anywhere from 5-20 minutes then it stalls.no warning.no check engine light.once the car stalls it takes a good 5-10 minutes to restart.it cranks and tries to turn over but no luck right after it stalls.suggestions, ideas,please help!!!i cant keep sinking money into this care playing the guessing game!
Old Jul 27, 2017 | 06:46 AM
have you had it scanned for trouble codes? sure sounds like a icm but no way to know for sure.
Old Jul 27, 2017 | 07:30 AM
ICM testing is not 100% accurate. Especially on an intermittent issue. In fact, I would say they are very unlikely to find an issue that only effects the car after running 5 minutes.
When a Car won't start its missing something. The question is what is it missing?
You want to check fuel pressure (Running good and no start condition)
Spark (with a spark strength tester)
Last you need to check to be sure the injector is cycling (use and injector noid light)
(DO NOT USE a test light or old volt meter, they can draw more power then the PCM can handle and fry your ECM)
Keep in mind just because you replaced a part is not 100% guaranty that it is working correctly. You need to test to prove it is working. I put 3 airtex fuel pumps in my 96 before I got one that worked right.
Old Jul 28, 2017 | 08:10 PM
Jmm5712's Avatar
Im still at a loss here.car almost seems like it was vapor locking.unscrewed the gaa cap last night and ran it,ran fine.never shut off.today,it ran for about 10 mins and shut off on the highway.today,it took 30 mins to restart.after it shut off about 5 minutes later i thought i heard a relay click.when it did start 30 mins later i took it home immediately. 3 hours later i got in it and its trying to fire but wont start at all now.getting frustrated trying different things and still no check engine light comes on.
Old Jul 28, 2017 | 08:24 PM
You are going to need to test for what is missing. With 40 PSI and submerged pump vapor lock is not a thing.
ryans95z
Jan 27, 2010 12:39 AM
Z28 Heritage ragtop
82-92 V8 Tech
Oct 4, 2009 02:48 AM
porky
82-92 V6 Tech
Jan 6, 2008 05:26 PM
91ConvertibleCamaro
Jan 1, 2006 03:24 PM
