97 Z28 wierd sound after driving awhile
Old Sep 22, 2018 | 04:30 PM
Tipsy's Avatar
Default 97 Z28 wierd sound after driving awhile
Hi everyone,
Well the title says a lot here. I have a 97 Z28 with automatic trans, 127,XXX miles and when I first pull out of the garage it does not make this sound but after driving awhile, like say 20 minutes at least, when I make a turn left or right I can hear some sort of rubbing or scraping type of sound. Seems to come from the rear area. My mechanic and I can duplicate the sound in the parking lot but once it's up on the lift we can not find anything wrong or out of place. So, it's something that happens on the ground under the weight of the car and it's happening during a turn and after things are warmed up, which makes me wonder about things like rear brake pads or would my tires be swelling a little but I don't see any marks from rubbing anywhere? I don't know.
Anyone have any ideas of what to look for?
Thanks! You've all been so helpful in the past, I really appreciate it.
Jeff
Old Sep 22, 2018 | 08:02 PM
Sure sounds like an issue with your deferential. The deferential allows the rear wheels to turn at different speeds. The harder you turn the more the deferential has to work. Your Z28 has limited slip/Positive traction to prevent one tire from spinning under hard acceleration. As you can see one system allows the tire to slip and the other system tries to limits how much it slips, It is common for there to act up when hot and there is an additive you can add that may quit it down.
Old Sep 22, 2018 | 08:04 PM
Y2K's Avatar
Y2K
Yup posi unit going south.
Old Sep 23, 2018 | 10:39 AM
Tipsy's Avatar
Thanks Gorn and Y2K. Gorn can you advise what the special additive is?
Jeff
Old Sep 23, 2018 | 11:09 AM
Y2K's Avatar
Y2K
Jeff
There's many different brands but basically it's this stuff.
Old Sep 23, 2018 | 11:11 AM
Tipsy's Avatar
Awesome! Thanks!
Old Sep 27, 2018 | 08:02 AM
Tipsy's Avatar
UPDATE!
It worked. I needed to replace my pinion seal anyway so did that and put some magic solution in and so far no noise!
Thanks again everybody.
Jeff
Old Sep 27, 2018 | 09:18 PM
Y2K's Avatar
Y2K
Thumbs up
UPDATE!
Jeff
Great!
Tipsy
Jul 5, 2016 07:32 PM
rs657f
Feb 10, 2016 11:25 AM
rs657f
Feb 24, 2013 05:29 PM
94ChevyCamaroV6
Oct 1, 2011 11:44 AM
99C.Chick
LS Series Tech
Aug 29, 2005 01:00 AM
