97 z28 rough idle and shut off
Old Feb 28, 2018 | 01:19 PM
97z28white's Avatar
Default 97 z28 rough idle and shut off
My stock 97 z28 has been idling rough and also shutting off on me when I come to a stop. The only thing done to the car is I did the torqhead Opti delete and it worked great for about 3 months and all of the sudden it started to stutter every time it would shift into 2nd gear. Replaced the crank sensor on torqhead kit and that seemed to go away but it now is idling rough and shutting off after I've been stopped for 4-6 seconds. Need help!!!
Old Feb 28, 2018 | 07:57 PM
have you tried scanning for trouble codes.
Old Feb 28, 2018 | 08:23 PM
97z28white's Avatar
It's not throwing any codes...the ses light will cut on when it stumbles but then cut off once it smooths out or when it shuts off
not sure what the system you have uses. unhappy fuel pump, ignition control module, iac, tps, map, maf, plugged cat, thats all i can think of..
Old Feb 28, 2018 | 08:25 PM
double check the connections and wires at the crank/cam sensors
Old Feb 28, 2018 | 08:32 PM
97z28white's Avatar
Crank and cam connections I've already checked....fuel pressure is at 36-37 at idle which I know is low but wouldn't think a couple psi low would cause all of this. Also I took my battery/system check machine and said I had some bad diodes in the alternator and my dash cluster head and tail lights are always flickering
Old Feb 28, 2018 | 09:17 PM
almost sounds like a ignition switch problem. or wiring. check plugins on the pcm?
Old Feb 28, 2018 | 09:21 PM
check your fuses, for sure the ignition fuse. more so the tangs where the fuse plugs into. sometimes they can get crud grown on it or they just dont come together enough to connect to the fuse right.
simplyfast
Oct 20, 2016 07:57 PM
Justin Ellis
Jun 27, 2016 04:45 PM
Lbceelt1
Feb 11, 2013 01:30 PM
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
CJ51974
Jun 1, 2009 08:59 PM
