97 ss coolant fans
Old Mar 19, 2009 | 03:25 PM
ss2263's Avatar
Default 97 ss coolant fans
hey guys brand new to the site.love camaros. i have a bone stock 97 ss. just insalled slp manual fan switch but only 1 fan works. (low speed doesn't work) the fan is good relays are good (replaced all 3) fan does't come on with ac either what gives? any help would be great thanx
Old Mar 20, 2009 | 10:12 AM
The fans in your car use a fairly complicated circuit using three relays, and a simple on-off switch is not going to work right. These relays are controlled by the PCM. For low speed the relays connect the fans in a series circuit with each fan getting only 6 Volts and so run at 1/2 speed. At high speed the PCM operates the relays to connect the fans in a parallel circuit and each fan now gets 12 Volts, and the fans run at high speed.
Old Mar 20, 2009 | 06:07 PM
ss2263's Avatar
thanks for the information. i guess that just proves im just dumb enuff to be a little smart
Old Mar 20, 2009 | 07:01 PM
02StanGT's Avatar
I would think something is wrong if the SLP manual switch isn't running it on low speed. My SLP switch works with both low and high speeds.
Greg08
Oct 4, 2012 09:31 AM
Camaro3800V6
Aug 17, 2011 03:47 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
hp1cart@yahoo.com
May 14, 2009 06:36 AM
