97 camaro 3.8 clutch wont bleed
Old Dec 21, 2011 | 04:48 PM
mrlazar75's Avatar
Default 97 camaro 3.8 clutch wont bleed
so i replaced my clutch with a stage 2 clutch, put a new slave cylinder on and replaced the throw out bearing. me and a buddy are trying to bleed the clutch and cant seem to build pressure on the clutch. the fluid comes out but i dont feel a thing on the clutch. its a 97 camaro with a 3.8l and a t5 transmission. anyone have any ideas?
Old Dec 22, 2011 | 07:22 AM
3800camaro's Avatar
Sounds like a bad master cylinder.
Old Dec 22, 2011 | 07:29 AM
mrlazar75's Avatar
from earlier posts that ive been reading on this forum, i have noticed other with the same issue and i think either lots of brake bleeding or a vacuum bleed might be the solution.
Old Dec 22, 2011 | 11:26 AM
How are you bleeding it? Press clutch, open bleeder, close bleeder, release clutch. Repeat. If you release clutch wit the valve open you are drawing air back into the system. I don't think gravity bleeding is going to work at all.
Old Dec 22, 2011 | 10:23 PM
mrlazar75's Avatar
ive been doing that and i still have no clutch feel. not sure if im being impatient or what. ive probably pumped that clutch over 100 times.
jbarnett
Apr 22, 2014 02:53 PM
Descrasnezul
Sep 4, 2013 08:16 PM
ChaosUSN
Feb 2, 2006 01:48 PM
devile
Dec 27, 2005 05:49 PM
