96 camaro window & radio don't work
Old 09-29-2011, 12:25 AM
Chevyguy004's Avatar
Default 96 camaro window & radio don't work
My 96 camaro's windows and radio don't work. The radio comes to life every once and while but dosnt stay on. I have read that it my be the power window control module , which I think is the rap module( retained accessory power) on a 95 camaro but not sure if it's the same thing.
My car is a 96 camaro v6 3.8, any help with this would be great, before I spend a bunch of money on parts that won't fix the problem.
Please help! thank you in advance..
Old 09-29-2011, 04:34 AM
iLL95's Avatar
I Like to Party
Super Member
Check your fuses and get back to us
Old 09-29-2011, 06:13 AM
BasicConcepts's Avatar
Technical User
Old 09-29-2011, 11:53 AM
Thx for the replay guys. I did check them all and there good. Is there a good way to check ground to them?
Old 09-29-2011, 02:02 PM
Technical User
the fuses???? its not a fuse its 100% the bcm... unless you have a bad radio and a bad set of window motors at the same time
Old 09-29-2011, 05:00 PM
Spatfieya's Avatar
Yeah if you're fuses at both sides are getting 12v+ then you're good. Only when it's below 12v should you check your battery for low voltage or loss of voltage through a bad ground.
Old 09-29-2011, 10:17 PM
So u don't think it's the module (pwc) ? On a 96 it located under dash on driver side almost behind radio. And where is the bcm located? Is it something I can check and repair or dealer? Also what do I check for to find the trouble in the bcm? Sry for all the ? Lol, just want this resolved, hate having no music lol...
Old 09-29-2011, 10:20 PM
Window control be nice too lol thx again guys for help.
Old 09-29-2011, 10:21 PM
Technical User
read the link i gave you it explains everything
Old 09-30-2011, 12:09 AM
Wow just what I needed, thank you so much. going to try that , will let u guys know how it works out.
Quick Reply: 96 camaro window & radio don't work
