96 3.8 to 93 lt1
Old May 5, 2019 | 08:38 PM
DevonWadeHankins's Avatar
Default 96 3.8 to 93 lt1
I'm need help with my 96 rs, I took the 3.8 out of the car and put the lt1 ,motor transmission the whole k member,out of the 93 donor car, it will turn over but not crank, I was told that would have to take the airbag sensor out, what all wiring do I need I have dash wiring harness just not trying to take the dash apart... any help is appreciated thank you
Old May 6, 2019 | 04:16 PM
What you are doing is one of the more difficult swaps. The problem is the 93 has a Pre OBD computers system. It is basically the same system GM used through the 80's. The computer is call a ECM. (Engine Control Module). In 1994 GM switch to a system called OBD, with that the computer was then called a PCM (Powertrain Control Module). The two systems where pretty different. In 1995 GM switched to a OBD1.5 and then in 1996 it became OBD2. There is very little that is the same from 1993 to 1996. You have a choice make everything the 96 wiring or make everything 93. I am talking about the dash cluster and all the wiring. Just about every wire in the car except the headlights.
The real killer is your 1996 has a body control module is controlled by the 1996 PCM. Your donor 93 ECM has no connection to this and the body control module controls AC/Heat Power windows, door locks.... pretty much everything but the lights.
In all swaps the instrument cluster needed.
3.4/3.8 V6 to LT1
With LS1's there are people that make custom harnesses but I do not know of anyone making them for LT1s.
Old May 7, 2019 | 06:36 AM
Thank you, that was kinda what I was afraid of, I appreciate all the help and words of wisdom.... do you or any other camero lover know where I could find a ls1 on the cheapish price range?
Old May 7, 2019 | 09:17 AM
Cheap LS1s do not exist. People are buy running driving cars and taking out the drivetrains just so they can get an LS1/trans. Now you can find cheap truck 4.8's and 5.3's. The early ones are cast iron but they will work. The down side is you would still need a LS1 donor car for all the parts you need. Also the trans has a different bolt pattern.
This thread give you an idea on what is needed to do a truck engine swap the right way without a donor car. With what these cars cost now I would not call it cheap.
https://camaroforums.com/forum/93-02...v8-swap-78734/
IMO Your only cheap option to get your car back on the road is to go back to the 3800. The 3800's are cheap and everywhere. We have seen people find motor for with under 40k for less then $500. What most people don't know is you can put a front wheel drive 3800 in a camaro if you just use the long block and those GM made up till 2009.
camaroteen82
Apr 17, 2014 09:53 PM
dropcivic
Jun 30, 2011 09:04 AM
1998camarossclone
Apr 4, 2011 08:47 PM
LT1sbc
Aug 26, 2010 02:41 PM
two1996chevys
Dec 4, 2008 10:24 AM
