95 Z28 74k miles head gasket
Old Mar 13, 2014 | 01:48 PM
DrQuincy's Avatar
Wow. For $2010, I was able to have the head gasket replaced, the heads checked, the compression tested, and the water pump and Opti replaced.
Old Mar 14, 2014 | 04:52 AM
grasshopper645's Avatar
do all auto 4th gens have a overheat light for the transmission? where is it located?
Old Mar 14, 2014 | 08:49 AM
i had a high temp light come on quite a while back, scanned for codes and came up with trans high temp code. seemed like it was to the right of the speedo. ill have cluster out in the next day or two, ill have a look.
Old Mar 14, 2014 | 09:05 PM
Originally Posted by curtismc56@hotmail.com
I did have the car towed and diagnosed with instructions of temp and died. They called it gasket from below and then on top. They saw where the coolant leaked from. Upon further they sent the heads to be machined and found valves were damaged. With tax $2864.
They will replace heat sensor with wires plugs and ancillary parts etc.
It got that hot that it damaged the valves? That sucks, there is no way of knowing if there is any other damage. I hope the rings and block are ok.
Man that is a lot of money. For around $3200 you could of had a remanufactured motor installed.
hyflyr
Feb 21, 2012 08:26 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
ryden
Mar 14, 2010 05:30 PM
dcanada53
Mar 5, 2008 06:01 PM
trailerparktrash2009
Nov 14, 2006 11:05 PM
