95 Frames
Old Apr 9, 2017 | 09:38 PM
Aaron Tracy Sharp's Avatar
Default 95 Frames
Hey guys I'm new to the camaro scene. I'm looking into a serious street strip build. I have the chance to buy a car cheap and have a question. On fourth gens are there any major differences in the frames of a v6 car vs a v8? The car is v6 and I'm going to swap in a lq9 if the frame can handle it and not have major strength issues.
Old Apr 10, 2017 | 07:39 AM
basic frame is the same, k member is different, springs are different, computer and running gear is different.
Old Apr 10, 2017 | 08:40 AM
You can switch the K-member, It does not matter which car you buy but I would pick up a 98-02 LS1 K-member, If you do then the LQ9 is a direct bolt-in with an LS1 oil pan.
Old Apr 10, 2017 | 10:41 PM
Thanks for the info!! So I was thinking an aftermarket K-member. Your saying that year k member is direct bolt in. So literally no special mount fabrications? I'm no the best with cars. I'm a heavy equipment tech but I want to build a full on race car. Money is not a problem.
Old Apr 11, 2017 | 05:51 AM
All 4th gens have the same K member mounting. Meaning a 2002 Kmember will bolt into a 1993. The only real difference is they are engine specific. If you look in the project section there are a couple V6 to race car threads.
Old Apr 11, 2017 | 07:56 PM
spohns makes a nice heavy duty kmember an control arms. also would recomend weld in sub frame connectors, shock tower brace wouldnt hurt and tunnel brace relocation of the torque bar.
HotrodsandMusclecars
Mar 25, 2016 11:56 AM
overhaul2
Nov 11, 2011 10:21 PM
nonrestorer
Feb 8, 2008 12:57 PM
