95 camaro v6 3.4 letter problem please help
iv been having a problem with my car. At 30 % throttle it accelerates fine, but when i put my foot in it, the car doesnt have as much horse power as it should, it still revs up and accelerates but it back fires alittle and doesnt preform like it should, when you let off the throttle alittle bit it picks up and go's. it has a check engine light which i got checked and they said it was running lean on the driver side, he showed me on the obd2 reader that said about 700 something on passenger side and 100 something on the driver side. which i guess is compression ratio or fuel presser idk. but he said it should me 700 on both sides. my dad thought maybe replacing the o2 sensor for that side of the engine would help fix it but it hasn't yet. i was thinking that maybe it was a vacuum leak like from the intake manifold gasket or head gasket on that side of the motor. my dad said if it was the vacuum line it would run like that on both sides. if anyone knows what i should do please tell me. i don't wanna buy a 50 dollar gasket set and rebuild my motor if it doesn't need it. thanks josh
Lean condition is caused by too much air or not enough fuel. The fact it is on one side of the engine helps. O2 sensor was a good guess.
I would try swaping injectors side to side and see if the issue follows. It is most likely not fuel pressure or it would be both side but it would not hurt to check the pressure.
Vacuum leak should increase your idle to high RPMs, Is your idle high? Some vacuum ports feed on a single runner so a vacuum leak could cause a lean issue and not have a large increase in RPMs. Check the drivers side. Another thing you can try is pinching off vacuum hoses with needle nose plyers and see if the motor changes in sound. Two big ones to check are the PVC valve and the brake booster.
I used a $20k snap on reader and it told me everything about my car :P
