-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   95 camaro v6 3.4 letter problem please help (https://camaroforums.com/forum/93-02-general-41/95-camaro-v6-3-4-letter-problem-please-help-67069/)
stormmage88 01-02-2012 03:32 PM
iv been having a problem with my car. At 30 % throttle it accelerates fine, but when i put my foot in it, the car doesnt have as much horse power as it should, it still revs up and accelerates but it back fires alittle and doesnt preform like it should, when you let off the throttle alittle bit it picks up and go's. it has a check engine light which i got checked and they said it was running lean on the driver side, he showed me on the obd2 reader that said about 700 something on passenger side and 100 something on the driver side. which i guess is compression ratio or fuel presser idk. but he said it should me 700 on both sides. my dad thought maybe replacing the o2 sensor for that side of the engine would help fix it but it hasn't yet. i was thinking that maybe it was a vacuum leak like from the intake manifold gasket or head gasket on that side of the motor. my dad said if it was the vacuum line it would run like that on both sides. if anyone knows what i should do please tell me. i don't wanna buy a 50 dollar gasket set and rebuild my motor if it doesn't need it. thanks josh
Gorn 01-02-2012 04:34 PM
There is no way anyone could know what wrong with your car because it could be so many things. This is a EFI drivability issue and would demand a "A" class mechainc in most shops.
Lean condition is caused by too much air or not enough fuel. The fact it is on one side of the engine helps. O2 sensor was a good guess.
I would try swaping injectors side to side and see if the issue follows. It is most likely not fuel pressure or it would be both side but it would not hurt to check the pressure.
Vacuum leak should increase your idle to high RPMs, Is your idle high? Some vacuum ports feed on a single runner so a vacuum leak could cause a lean issue and not have a large increase in RPMs. Check the drivers side. Another thing you can try is pinching off vacuum hoses with needle nose plyers and see if the motor changes in sound. Two big ones to check are the PVC valve and the brake booster.
BasicConcepts 01-02-2012 05:41 PM
You actually saw the reader??? I only ask because your car should be obd1
stormmage88 01-02-2012 08:55 PM
yes i saw the reader, it has a obd2 plug and will work with a obd2 reader
no my idle isnt high
BasicConcepts 01-02-2012 09:19 PM
odd my 95 with an obdII plug didnt work with an obdII scanner maybe yours is a late model
stormmage88 01-03-2012 12:40 AM
i dont know i got it read at a business called autoport inc. in meridian ms
Socom 01-03-2012 10:59 AM
I used a $20k snap on reader and it told me everything about my car :P
m-samuels@sbcglobal.net 01-04-2012 02:35 PM
Check map sensor,it could throw ur car in a loop.took me 1yr to figure it out.Lol
craby 01-04-2012 04:52 PM
have your injectors cleaned and flow tested at a injector shop, not that expensive. if cost is not a factor i would change the other 02 sensor. check air filter.
