95 camaro terrible noise
Old 02-02-2021, 12:26 AM
HornyOldLady's Avatar
Default 95 camaro terrible noise
Terrible errrr noise coming from the dash when I start my car. I normally have to shut it off/open close my door to get it to go away. Sometimes it takes a few tries. Any ideas on what it could be?
Old 02-02-2021, 06:04 AM
Everett#2390's Avatar
The noise may be the actuators for the heating/AC system opening/closing the doors, ie, HEAT, DEF, DASH/FLOOR outlet from their preset location.
Old 02-02-2021, 04:40 PM
I have no idea but your handle gave me a good laugh.
Old 02-05-2021, 02:08 PM
the driver window doesn't work either and if I push the button to roll it down it starts the noise up again. It's a whining noise from the dash
Old 02-08-2021, 08:39 AM
I would look at the wiring where it goes from the door to the body, by the door hinges there is a passthrough that is covered with a rubber boot sorta thing. if you have a short it may be setting off a relay causing it to make noise. have a look here its a good place to search, 4th Gen LT1 F-Body Tech Aids also if you haven't download the factory service manual for your year here https://www.mediafire.com/?40mfgeoe4ctti
B_Dubya
08-10-2015 03:52 PM
nagysauto
11-25-2012 05:02 PM
spencer215
82-92 V8 Tech
03-15-2009 06:33 PM
BoricuaHec01
08-13-2008 12:45 AM
Saint_Ali
11-14-2007 12:45 PM
Quick Reply: 95 camaro terrible noise
