95 camaro noise
Old Dec 5, 2011 | 03:15 PM
gofastturnleft70's Avatar
Default 95 camaro noise
i have a 95 camaro and have not had it long i have replaced the wheel bearings and ball joints and every once in a while while driving i can hear a clunking noise behind the lf wheel sounds like it is at the back of fender/in front of door area and low to the ground anyone know what it might be. i was thinking control arm bushings but there is no weird things going on in the steering when it does this and it only does it every now and then
Old Dec 6, 2011 | 06:33 AM
does it do it on turns? could be ball joint or control arm bushing.
Old Dec 6, 2011 | 10:44 AM
iLL95's Avatar
I Like to Party
Super Member
It's most likely a ball joint, when I went to get a new set of tires the inspection offical said I had a bad ball joint, I could definitely hear (and somewhat feel) the clunking
Old Dec 6, 2011 | 11:47 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Could also be sway bar end links.
Old Dec 12, 2011 | 06:32 PM
my computer went down just got it back thats why i have not responded i put all new ball joints on and sway bar end links on but im thinking it is the control arm bushings to. and no it dont do it when i turn only does it about 1 in 3 times i drive the car
B_Dubya
Mar 27, 2015 02:10 PM
Greg Carter
Mar 15, 2013 01:21 PM
juan_leal1992
Aug 28, 2012 03:04 PM
tripwire1124
May 10, 2009 09:21 PM
rawktiludrop
Feb 13, 2009 10:34 PM
