95 camaro lt1 shudder vibration
Old Apr 9, 2009 | 12:55 PM
95slvrZ28's Avatar
Does the shudder happen only when you're in Park, or does it happen when you're driving as well?
Old Apr 9, 2009 | 07:38 PM
DAVIDP2000's Avatar
It happens in park at 2500 rpm and while iam driving it gets worst at higher speeds.....I took it to a shop today they are also baffled. He seperated the torque converter from the flywheel and it got quieter but still vibration was there. I hate to just put a flywheel and torque converter in and still be with the shudder-vibration.
Old Apr 9, 2009 | 08:51 PM
yep you are decribing the same thing i was feeling. right after i changed the trans mount i thought at first the motor or trany was wack. that was when i first found this site. i was reading on here for three days and seen about how the poly trans mount could do that. i thought man could it be that easy. figured it was worth a try. i think it was 18 bucks for the stock mount. took about 20 min. to change. im not sure thats what your problem is but it might be worth a try.
98rs
Jan 25, 2012 08:30 AM
Thunder66
Jan 27, 2010 08:57 PM
libertyforall1776
Nov 13, 2009 04:35 PM
gadmhahn
70-81 V8 Tech
Apr 5, 2009 09:51 PM
chopper14116
Apr 14, 2006 09:13 PM
