95 camaro 3.4 gas in exaust
raw gas is pouring out of the exhaust of my 95 3.4 camaro, it only occurs when the engine is being started, at first it seemed as though it was going to run fine, until this morning when I tried to start it and it seemed as though it was being flooded. any ideas on what could cause this?
RE: 95 camaro 3.4 gas in exaust
How do you know it's raw gas? It was running fine before? Only things I can think of that would explain gas in the exhaust, are leaky fuel injectors and/or weak/no spark... These would also give you your symptoms you described.
