95 3.4 oil pan change
Old Nov 14, 2018 | 04:38 PM
bugstune's Avatar
Default 95 3.4 oil pan change
Im changing my oil pan because it’s leaking, I’ve done as much research I can and I have a good understanding of what I need to do but I’m a little stuck. Does anyone know if I need to take off the timing cover and starter on a 95 3.4 V6 to take of oil pan? Some sources say yes some no but not clear; if u have changed the oil pan on ur car any tips or tricks? Thanks
Old Nov 20, 2018 | 04:43 AM
not sure if the starter absolutely has to come off but it will make your project so much easier to take it off. not sure why you would need to take front cover off but then i have never worked on a 3.4. did change pan gasket on lt1 and had to lower the rear of the trans a bit to get it to clear, also had to rotate the engine to get the crankshaft to line up as to not stick down and get in the way.
blink18236dude
Sep 7, 2024 06:17 PM
mike in ohio
Mar 6, 2011 09:21 PM
Vandee
Dec 11, 2009 04:02 PM
SSV6
Aug 17, 2007 09:32 PM
libertyforall1776
May 22, 2007 06:16 PM
