94 z28 runs terrible when at operating temperature? Help!
Old 12-31-2018, 09:58 AM
Y2K's Avatar
Y2K
Y2K is offline
Originally Posted by Sprenkel86
Just so weird that the warmer its the worse it is. It will actually get bad enough to die and not restart until it cools back down.
I don't know about others but when the new "rebuilt?" World Products Opti the mechanic installed in my '93 went bad after only 10K miles it acted exactly like that.
It would start right up dead cold but after warming up would start crapping out and eventually die, after a cool off it would start again.
One day it just wouldn't re-start at all.
Unfortunately the car wasn't a daily driver and the warranty was up despite the low mileage, I bought another low cost Opti online and then sold the car.
  #22
Old 12-31-2018, 10:47 AM
Sprenkel86's Avatar
Originally Posted by craby
pull the 02 sensors and see if they is fouled. gona have to find a good scanner and see whats going on.
I have an otc scanner that will tell me everything but I just don't know what to look for. The O2's have very low mileage on them and from what I was told if you unhook the maf it won't read them and stay in closed loop. Still acts up that was as well and throws and ses light and kicks the fans on with the maf unhooked
  #23
Old 12-31-2018, 10:50 AM
Sprenkel86's Avatar
I just put this msd distributor in because the car was acting the same way with the old one so I assumed it was the opti. $500 later car still does it. I went with msd since they converted to vented style. I thought it would be more reliable. Starting to wonder if it's junk too.
  #24
Old 12-31-2018, 11:48 AM
did you lock tight the rotor screws?
  #25
Old 12-31-2018, 11:49 AM
ses light,,, whats the trouble codes?
  #26
Old 12-31-2018, 09:17 PM
Sprenkel86's Avatar
The ses light only comes on when I unhook the maf to keep it in closed loop. And no I didn't lock tight the rotor I just put the distributor on. But that's not the issue since I just put it on and it hasn't ran right since I put it on.
  #27
Old 01-01-2019, 07:42 AM
look for what temp the computer is seeing. may have a short in wiring
  #28
Old 01-05-2019, 02:20 PM
Sprenkel86's Avatar
Put the hypertech coil on and as soon as the car started it was missing and stumbling and running rich as hell. No clue what to do now. Could the ecm be bad and causing the issues?
  #29
Old 01-05-2019, 10:17 PM
yes it can. i get the feeling your going to be better off getting to a good shop with a tech 2 scanner.
  #30
Old 01-13-2019, 07:15 PM
Sprenkel86's Avatar
It seems like different days it runs different. When I changed the coil it was warm and raining. When I started it it ran like poop from the time I started it. Later in a cooler dryer day is started and ran better for a little. Something with temp or moisture is changing it.
Quick Reply: 94 z28 runs terrible when at operating temperature? Help!
