94 v6 rear end swap
I have a 94 camaro v6 5 speed my friend is giving me a rear end out of a 95 z28 auto I was going to put it in my car but I don't know what problems I might run into has anyone done this before?
the only issue u may see is if one differential has traction control and one doesnt. a traction control rear end will have a sensor at each wheel and a rear end with abs only will have one sensor at the center of the differential at the top. if they are both the same it should be a easy switch.
