94 camero v6 won't start.
I have a 94 camero. I have bypassed the vats system, changed the fuel pump, new fuel filter, new plugs and wires , checked all fuses, good battery, it will crank but will not start. Running out of ideas any help wou ld be much appreciated.
Have not tried that yet. I will as soon as it quits raining. Thanks for the info. I will let you know.
Well l changed the plugs and still no start. I did find that the wires that enter the plug that goes to the lower side of the icm were deteriated and the bare wires are touching. I also found the ground wire that hooked to the left side of the body/frame had come unbolted the engine. Have to fix this and see what happens.
Ok so the car won't even turn over. Fuel pump primes dash lights come on, not even a click from the solinoid. I can bypass the relay that is back behind the glove box and it will turn over but has no spark. Getting tired of this thing. What else is there check?
