94 3.4 to 350
I have searched the forum and unable to find any help. I just bought a $500 94 3.4 v6 camaro with 205k miles that smokes. I am pulling the motor out now to install an older carb 350. I am wondering if there is anything that will have to be modded after the motor and trans is set in that anyone knows of?
You must be really bad at research.
You will need the front K frame from a V-8 car. You will need to cut away the dash and windshield to fit a standard carb intake and ignition system.
What trans will you be running?
Is this a race car or a street car? There is another thread where the guy just cut the cowl away to give him the room for the distributer. Is that an option for you?
once you cut away the cowl you will have room distributer. depending how much you cut you will be able to get to the cap and wires with out a problem. you will just have to take off the wiper arms and plastic cowl at the bottom of the windshild to get to them. the only problem i ran into to make my motor fit was that i had to cut out the pivot lever to the wiper trasmission and re locate it. if you use the lt1 k member and motor mounts you can make adapter plates to bolt to the first gen motor.
