93 z28 Aftermarket Radio Problem
Hey guys I have a question about the installation of an aftermarket radio in my 93 z28. This may be confusing but I'll try my best to explain.
The previous owner installed an aftermarket radio with a 20 pin power cable by taping, using adapters, and ghetto rigging the whole thing. Now, I just bought new radio with a 16 pin power connector. I'm pretty sure i see the stock power cables (blue/black?) how would I go about taking what I have now and making it compatible?
Thanks
Thanks
Thanks
Thanks
You need to find a wiring diagram of the stock radio wiring and then cut out what you don't need and wirer your new radio in, match the wires up from the new head unit to the stock wiring and cut out all connectors and tap ins the previous owner put in there. If you can go from your stock wiring directly to your head unit you'll get the best connection.
if thats the stock wiring you can just go to any speaker store and get a wiring harness. if its not stock just rip all the wires out until you get to the stock wires. and then you'll still need a wiring harness which does not come with your aftermarket stereo. so no matter what your going to need a wiring harness.
You can just unplug that
He still needs that adapter. The way the wiring works is stock plug connecter goes into an adapter that has wires coming out of that, that then are soldered to the plug that goes into the back of his head unit. I will post a pic later of what I mean.
