93 Camaro high idle
Old Dec 1, 2012 | 10:51 AM
BloodDragon's Avatar
I'll go over all the fuses today, grabbed a jumper key from work yesterday just on the off chance the wire I was using to jump the pins wasn't working, and had the same result ses light just stays lit.
Old Dec 1, 2012 | 02:14 PM
Well I'm at a loss, all fuses are good, cant find any wires under dash that have been butchered and spliced.
A new issue with the idle problem has appeared though, since the last ecu reset the ses light will come on at a stop light and idle will drop, ses light will go off and idle will go back up.
Old Dec 1, 2012 | 02:49 PM
gona have to start testing things. egr, evap system, iac, intake air temp sensor, ac relays. i would start with the iac, intake air control motor. most tests are here 4th Gen LT1 F-Body Tech Aids evap is here https://camaroforums.com/forum/93-02...rt-here-38462/
Old Dec 3, 2012 | 09:26 AM
I think I've got it down to having to do with the heater/defrost being on.
The last couple of days it has been warmer and I've had the heater/defrost off and it has idled normal.
Which I dont understand as all the ac equipment is gutted from the car.
Old Dec 3, 2012 | 11:49 AM
may be the computer is being told the ac pump should be on and if it is the idle needs to be up a little. thing is the computer is supposed to know the rpms and should try to hold at 8-900
r00tk1ll
Feb 6, 2015 10:25 PM
jasonkhodgdon
82-92 V8 Tech
Dec 19, 2012 05:29 PM
shoff24
Dec 31, 2010 01:15 AM
Need Mentors for Camaro
Nov 2, 2010 01:06 PM
NEW_CAMARO_OWNER
Aug 17, 2010 08:33 PM
