https://camaroforums.com/forum/
https://camaroforums.com/forum/93-02-general-41/
4th Gen General Info and Specs
https://camaroforums.com/forum/93-02-general-41/4th-gen-general-info-specs-71052/
craby
Aug 4, 2011 09:26 AM
1 93-02 parts manual;
https://camaroforums.com/forum/93-02...09/#post175314
2 heater information
https://camaroforums.com/forum/lt1-l...84/#post587081
2.5 gates heater and radiator hose replacement
https://www.gates.com/us/en/ymm/sear...gine=V-8+5.7+L
3 Steering column info
https://camaroforums.com/forum/4th-g...mn-info-64804/
4 Blinker wiring
https://camaroforums.com/forum/93-02...44/#post625627
5 LT1 tech1 data values
https://camaroforums.com/forum/lt1-l...-values-68546/
6 OBD 2 trouble codes;
https://camaroforums.com/forum/4th-g...i-codes-57023/
7 02 Camaro GM catalog;
https://camaroforums.com/forum/4th-g...alog-gm-52160/
8 GM rpo axle codes;
https://camaroforums.com/forum/4th-g...e-codes-54483/
8.5 How a differential works
https://camaroforums.com/forum/gener...l-works-72736/
9 GM rpo body codes;
https://camaroforums.com/forum/4th-g...o-codes-50977/
10 Decode VIN
http://www.chevy-camaro.com/chevy-ca...fourth-gen.asp
11 Remove LT1 from bottom
http://www.michiganspeed.com/enginepull/index.html
12 95 lt1 tech service bulletin
https://camaroforums.com/forum/lt1-l...lletins-68312/
13 95 location of everything
https://camaroforums.com/forum/lt1-l...ing-car-68314/
14 4th gen fluid capacities
https://camaroforums.com/forum/93-02...acities-70171/
15 Door and Window info
https://camaroforums.com/forum/lt1-l...25/#post639865
16 Vacuum hose routing
https://camaroforums.com/forum/93-02...4th-gen-68660/
17 Engine ID codes
https://camaroforums.com/forum/lt1-l...gine-id-73667/
18 fuel tank and pump delivery info
https://camaroforums.com/forum/lt1-l...76/#post687333
19 Viper alarm/key fob battery replacement
https://camaroforums.com/forum/93-02...00/#post748437
06:59 AM
