4th gen gears info
Old 12-22-2008 | 04:30 PM
lee33lyn's Avatar
Default 4th gen gears info
just got a 95 camaro and don't know what the gear ratio is. Can I find it at the same place as the third gen cars? On the axle tube front about 3inches towards the pass side. Its too cold to crawl under it now so I don't wanna spend too much time looking for it.
thanks
Old 12-22-2008 | 06:03 PM
Default RE: 4th gen gears info
Not much can be done with what you are telling us, except that it does not sound stock. Remove the cover on the rear end. It is always a good idea to change the rear end fluid. If it is a factory unit the ratio is usually stamped on the end of the ring gear. If not, count the number of teeth on the pinion gear and on the ring gear. Divide the number of teeth on the ring gear by the number of teeth on the pinion gear and you have the ratio.
Old 12-22-2008 | 06:47 PM
lee33lyn's Avatar
It should be stock. I looked in the RPO numbers and didn't see any mention of rear-end. The 3rd gens have the rearend code stamped into the tube on the axle about 3inches from the hogshead. I was hoping the 4th gen (which I'm new to) had some type of code somewhere on the car. I was going to get under it this weekend and try to find something.
thanks
Old 12-22-2008 | 07:07 PM
evilkal's Avatar
It will be an RPO code... GU(1-6) will be your gear ratio
Old 12-22-2008 | 07:12 PM
02StanGT's Avatar
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
Old 12-22-2008 | 08:18 PM
lee33lyn's Avatar
its gu6 , what about posi or limited slip diff?
Old 12-22-2008 | 08:23 PM
02StanGT's Avatar
You have a limited slip more then likely. I think the code is G80
Old 12-22-2008 | 08:41 PM
lee33lyn's Avatar
yes, I see a G80. thanks alot for the help!
mytchellm
07-13-2015 03:06 PM
hevymetalg
08-27-2011 11:02 PM
00camaro00
LS Series Tech
09-20-2007 01:11 AM
steve87iroc
General Racing/Tech
08-20-2007 05:47 PM
00camaross
LS Series Tech
10-18-2006 11:47 AM
Quick Reply: 4th gen gears info
