4l60e Question
Old Sep 20, 2010 | 08:49 PM
elyk10's Avatar
Default 4l60e Question
Quick question.
I'm replacing my trans out of my 95 z28, and I read somewhere where in 95 the 4l60e had some weird difference that year. So my question is, would I be able to replace it with another year? Anyone know what the differences are?
Thanks.
Old Sep 21, 2010 | 05:45 AM
you will want it out of a z28. you should look for the plugs on the trany to make sure yours is the same. the 93 has an odd trans, not sure on the 95.
Old Sep 21, 2010 | 03:11 PM
Grandpaswagon's Avatar
Make sure that you get it from a Camaro or Firebird. You do not want one out of a truck or other car.
You should be able to use the 4L60E from a '94-'97 I believe. I don't think that GM made (m)any changes to the F-Body 4L60E during those years.
Old Sep 22, 2010 | 08:20 AM
1augapfel's Avatar
I took a look at the parts pdf right after the initial post appeared. The GM reman unit is different each year for 94, 95, 96, and 97. So as far as GM is concerned you need a 95 transmission.
Salvage yards, however, use something called the Hollander Interchange Manual. That book tells them what parts are close enough in function to fit and work properly. The guys at Hollander do extensive research each year to see what part numbers have changed for the major components on all cars. It's a HUGE job.
If you call any large salvage yard they can tell you what "The Hollander" says will work. Whether they *will* tell you is another issue.
camarojunkie97
Dec 11, 2012 10:35 AM
timmyz28
Apr 16, 2010 10:24 PM
sewerrat
Dec 9, 2006 04:01 PM
RatedZ
Mar 13, 2006 03:49 AM
bjames5
Jan 16, 2006 10:55 AM
