3.8 to 3.8TT swap questions
Old Jun 18, 2007 | 12:27 PM
SSV6's Avatar
Default 3.8 to 3.8TT swap questions
I just need to know if the bell housing is the same on the 85-87 buick grand national, the 3.4 of the same 4th generation body, and the 3.8 of the 4th generation body are the same, if not, who sells adaptor plates?
Old Jun 18, 2007 | 01:14 PM
squisher's Avatar
Default RE: 3.8 to 3.8TT swap questions
Bolt pattern I'm sure is the same for the 3.4 and 3.8 (and therefore bellhousing) of the 4th Gen F-bodies, not sure about the older 3.8 blocks, but probably. Might check around in any Buick forums if you can for info on the older engine. (85-85 *might* still be BOP pattern, but then again, I think BOP is specifically for V8s). If it's not the GM v6 pattern, then it will likely be BOP.
Old Jun 19, 2007 | 08:07 AM
SSV6's Avatar
Next question, in swapping over my harness, will the instruments on the dash still work? My coworker informed me that I'll be lucky to have a speedometer.
palmers68
Oct 16, 2019 10:51 PM
chevyguy912
82-92 V8 Tech
Jan 5, 2012 11:56 AM
Senshi09
Dec 26, 2011 06:21 PM
project blackjack
82-92 V8 Tech
10
Jan 26, 2010 09:39 AM
jamguitarist91
Sep 19, 2008 02:47 PM
