3.4 PCV Valve Location
Old Feb 17, 2014 | 02:42 PM
Mikeroc283's Avatar
Default 3.4 PCV Valve Location
So i searched the site for info on where it is but cant find any info. Where the hell is it?
Old Feb 17, 2014 | 02:51 PM
Mikeroc283's Avatar
Found it. Weirdest spot to put it where it can hardly be seen.
Old Feb 17, 2014 | 04:13 PM
lol, glad you could help you. have you downloaded the factory service manual for your year. http://www.mediafire.com/?40mfgeoe4ctti click on fb94
Old Feb 17, 2014 | 08:50 PM
Mikeroc283's Avatar
Any thing i didnt think of to make my mileage go up?
Old Feb 17, 2014 | 08:58 PM
what have you done so far?
Old Feb 17, 2014 | 09:00 PM
Mikeroc283's Avatar
Both O2 sensors, replacement wires from autozone with double platinum plugs, and the pcv valve. I plan on the MSD coils and Taylor wires. Factory coils are only 20,000 volts from the sites i have read.
Old Feb 18, 2014 | 10:36 AM
air filter, brakes, test fuel pressure, outer tie rod ends go every 20-40k miles, shocks, check ball joints and wheel bearings, borla exhaust, kill stereo, wheels and tires,
Old Feb 18, 2014 | 01:40 PM
Mikeroc283's Avatar
Has cold air intake, Needs driverside outer tierod end, shocks need changing, has no converter with a flowmaster muffler, dont know on bearings or ball joints, still need to check the pressure.
Old Feb 18, 2014 | 01:55 PM
ball joints have a wear indicator on em.
http://repairguide.autozone.com/znet...528007de19.gif
Old Feb 18, 2014 | 05:04 PM
Mikeroc283's Avatar
I sea foamed it earlier. No difference. Still idles at 1000 rpm. Took it on the highway behind my house, had it up to 80 and it was shaking all over like the wheels arent balanced or something is loose.
